You thoughts on traction arms lipp or a1?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i loved my car when i full out fixed my hop issue full nice strips in secound befor hopped liek freaking bunny rabbit
custom tration arms
reinfroceds sub frame
semi soilid sub frame montes
ajustablte rear end links for the st sway bars
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hemi joints on road car are ok just matter were you use them
the best part abotu them is you can load down the tration arm to certon point were it does not become a spring
IJ. said:
Heim joints in a road car = :barf:
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Ian and I were discussing why the AL aren't being guaranteed anymore if they are sold through a third party (any company other than Greg's). He made them, you think he would warrant them no matter who is selling them brand new right?
Toy-Rific
145
Minnesota
The reason I made the light weight arms were the di-hard whom need them be light weight. The only ones that broke in the aluminum that I saw were caused by squeeze them together too much. This was on the u shape end and not the end that is up in the frame. It seemed that on a few cars the thickness of the mounting support was thinner, and /or the end of the traction arm was spread too much. So when the bolt was tighten down it would crack the arm and then would later break apart.
If the washers supplied were put between the inside of the arm to take up space that would have fixed it.
In the end, I did not want to put out a product that might fail so I stopped selling them. I believe there were 3 arms that broke and I offered a replacement with the same or could get steel if they wanted to.
The ones on e -bay are all good but they need to be installed the correct way and yes, I am not selling any more of the aluminum.
Thanks for reading this.
Greg Clark
Lipp/SS
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Greg, thanks for posting up, its nice to meet the man behind this... Do you own LIPP? Are you responsible for all the parts that come out of LIPP? Great designs!!!
Greg is Lipp ;)
That's why I couldn't understand the stance on SS as having e-mailed back and forth with Greg way back when Jeff owned SS Greg came across as very customer satisfaction oriented!
Toy-Rific
145
Minnesota
Yes,
I am Lipp ( Liberty International Performance Products) I produce parts for the Toyota Mark III, and the MR2, 2nd gen., Mitsubishi EVO, 3000 VR4 and the Mitsubishi 4G63 engine, I will be brining out a new performance turbo replacement for the Subaru and the MR2 that will bolt on as a direct factory replacement for a distributor.
Thanks for all of your support
Greg Clark
Toy-Rific
145
Minnesota
I have been very slow on listing what I make and sell. I do have a web site for the Lipp parts but have not open yet. The mitch parts I sell the most of is the transfer housing for the 5 speed replacement made out of 17-4 stainless steel. I also have the mid-section but it is not listed yet.I wholesale them, I don't get much call for them on a Toyota site. In all, Lipp makes about 35 to 40 different products.
Greg
Toy-Rific
145
Minnesota
Sorry, I am not on the post so back to it.
The alum arms that sell on E-bay are of good quality. I will not sell them any more because I give a warranty when sold and they may break. I don't want to be replacing them when you can buy a SS set that will not break.
I do have a few left in stock for replacement if the ones that were sold from SupraSport or from its wholesale companies. I am not giving free replacement for the ones sold on E-bay.
Greg
Sawbladz
1,727
Oshawa, ON, CA
I have heard that poly bushings can squeak. Would this be true in this application as well? I am about to buy some LIPP traction arms but I can't deciede on which bushings. I like the idea of the stiffer poly but I won't tolerate any squeaking.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Greg Clark
Lipp/SS
glad i got my steel then :) ive had no probs
tlo86
Jul 24, 2005
3,914
Colorado
ive had 0 squeek as well and i used the supplied grease (or it was the grease from the ST swaybar kit, either way poly bushing all around and no squeeks :) and its been almost 2 years )
