I don't know. You might be ok, might not. The offset is kinda important to wheel fitment.
If you're on stock suspension, I'll just guess you won't rub the fender. But if your offset is too high, you could be rubbing suspension parts. So who knows.
Offset is typically measured in millimeters (mm), good offset for 8.5 and 9.5 is +35 and +40 respectively. 19" is tall for the mkiii, but should fit with a very low profile tire 30-35 aspect ratio (depending on how wide of a tire you plan on going with).
