yellow bird cage light
K Spec
60
San Diego
Not everyone has an owner's manual. I can't get mine to stay off; no matter how much fluid I put in it, the light flashes in the corners. It must be the Gs I'm pulling. Once I get off my stock suspension, I will be unstoppable!:evil5:
N
NDBoost
Guest
bhgs are for pussy i straight up run mine hardcore, i run robitussin in my radiator. Keeps it from getting sick..
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
There was a thread a few days ago about someone that had the same problems with the light staying on. I think he added some foam to his float and it fixed his problems.
supramacist
1,501
The Grassy Knole
what part of the water pump did he put foam in??????? I don't think we are tottally on the same page......., and I would like to be. I dig your vibe joel even thought you are a moderator. I know Ij told you about me. I'm just trying to be cool.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
um i think he meant he put foam on the float in the overflow tank. not the water pump. yew mus be off yo hinges!
supra90turbo
shaeff is FTMFW!
32
MA, 01440
This thread confuses me.
Somehow teh museum/birdcage is related to the power steering pump, then the alternator, but now it's better, but you might need a water pump?
::grabs skull:: owie!
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Sorry for the confusion guys..., I was referring to Kspec post above mine when I was talking about the foam for the birdcage..
My bad...
supramacist
1,501
The Grassy Knole
This thread is messed up. It's all my fault, I was high when I started this obviously I am on crack. I can't believe we bought this car and I love this car. Hence the grand I am about to put into it.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
pff.... I must be crazy in love with my supra... dropped 4k into it within a month.... it's still completely stock... just restoring it is expensive.
supraman7mgte
Shut up,bitch!!
Sunny California
the float in the resivoir bottle might be stuck,faulty or just not working right. there might bea load of crap in there that you will have to clean out that was left by the previous owner.
if you continuously lose water,you obviously have a leak somewhere,if you have a bad water pump,it will start coming out of the "weep hole" on the bottom of the water pump.
but you replaced the bhg,right?
PHILLYSUPRA
serious
Jun 29, 2005
99
philly
AWW! thats what that light is. mines been on like 6 months after my HG fix. even though i got no temp rise or leaks how else would you know if your WP is going bad? clicking,knocking, fluctuating idle?
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
I also blew the right angle hose, I think it was the water pump bypass? You would know if it was that though, you would be spewing anti-freeze like a mofo. Scared the piss outa me when I was driving and saw steam and shat pouring out from under the hood.
