((alright i duplicated this thread in this section so it could get some more traffic, and it technically applies to both GE's and GTE's so it's legit!))
ok, i've tried 2 different fuel lines now (the one that sits on the end of the fuel rail and runs down through the intake manifold and connects to the main feed), neither fit correctly and it's driving me nuts.
one was off a turbo that i tried to retrofit (was told by toyota that it is the same on both) but that didn't fit for some reason, and one that i just bought isn't fitting either... i'm 99% sure these are the correct lines, and the correct placing of both ends but it doesn't seem to fit (i had to beat the previous turbo line on, and it did fit, but didn't seal correctly)
(excuse the size of the pictures, i didn't make them smaller so you could clearly see everything)
in the pictures it doesn't look like it's very far away from where it should fit, but it's deeper down than the line is running, theres no way it'll reach without me drastically altering the line
any advice?
any advice?
