WTF is this connector
ImCressid
28
newyork
Does anyone know what this connector is
Its a white round connector with three wires
2 blue
1 white
All about with 10 gauge
carter
"The Ninja"
Nov 1, 2005
743
Ohio
Can you post up another picture or what area its in... I'm thinkin thats the one on the intake side, but i can't remember if it was hooked up or where it went. lol Sorry
Is there any connector close around that it might plug into? lol i don't mean to sound like a dick i'm just askin
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Looks like a plug used in the transmission area even though its no where near that area.
Looking at this diagram http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=26
With This plug identification http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=26
Looks like maybe its A4?
By any chance does you car have ABS?
With this diagram is seems the ABS module is powered threw it, the two Blue wires. http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=110
Still investigating the white wire.
EDIT: White wire stems from the battery thrrew the HEATER circuit breaker powering the blower motor as end result.
Off Battery http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=036
Blower motor side http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=140
Easy test to see if thats it, does your blower motor work? The matching plug may be behind the fender.
reincaster
68
Guam
I had it on my n/a, and it was also not plugged into anything, but my car was a manual. If the op's car is manual as well, chances are it's for the auto tranny, but it was left in the harness.
ImCressid
28
newyork
Well to answer a few questions.
this is my pick up project its a Cressida with a GTE Conversion that starts but not running
The connector in question is by my Air Flow meter
I have a stripped interior so I have no heat or a/c
Im really just trying to get it running
What is NSS..Im thinking neutral safety switch
If it will get the car to start, ill deal with it, if not i ll leave it alone
--Golli
85
Adelaide, Australia
Isn't the Aircon relay on the same side as the battery??
I have the same connector on my post 89 7M-GTE. It doesnt connect to anything either and there is nothing around that area like it.
--Golli
85
Adelaide, Australia
Well that just answered my question! i've got a manaul and relays #2 and #3 are only used in the autos. Cheers!
Why would the Auto need 3 relays for the AC?
Unless it would just use one of those 3 relays.
/hijack....
/hijack....
Cos Auto's are bettereerr of course ;)
