Wtf? Dog box?
mattman
96
Michigan
So I was watching a vid on youtube with Travis Pastrana talking about his rally car (Subaru Impreza) and he said something about a dog box. So I looked up dog box and watched a few vids on them but still really know nothing about them. I know you dont need to let of the gas when shifting or even hit the clutch for that matter. But my real question is does anyone have one, and is it good?
Zach
ECUMaster USA
Apr 6, 2005
375
TX
Do some more searching and you'll find your answer. Nobody that I know of has one in a Mk3. Every dogbox I've seen runs straight cut gears (which are horrendously noisy). The expense is the big kicker, too. Search for hollinger and you'll probably find some dog boxes.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Wouldn't mind coming across a set of straight cut gears for my r-154...
figgie
Twin Cities, Minnesot-ah
JDMMA70;1130540 said:
Trust makes a gearbox for our cars, so do a few other japanese tuners.
Don't say. SHOW.
OS Giken USED to but they have pulled everything they used to have for the MA71/JZ71.
Most other companies have pulled thier offerings also.
JDMMA70
2,550
Houston
figgie;1130549 said:
Don't say. SHOW.
Let me change that to USED to make a transmission for our cars. I cant find it on their site anymore
gtimportfanatic
Mk3 Addict
May 21, 2008
277
Hartford CT
on the subject of whining.. my tranny is awefully loud now.. and the higher up i go in gears it becomes more evident.. i just changed the fluid.. and nothing better.. any idea what might be happening
shaeff
11
Around
figgie;1130529 said:
Shaeff
I am sure Xtrac would be more than happy to tackle that project for a nominal fee ;)
Depending on how much of a racecar it turns into, I might look into it. Thanks for the tip!
Never knew that, but Trust/Greddy just went bankrupt, so I doubt they'll be making any more of that stuff. :(
Don't say. SHOW.
I knew that OS Giken used to make straight cut gears for the r-154, I nearly had a set of them one ebay a year or two ago, but was outbid at the last second. :(
Wade T
7m Mk2 terror
Apr 6, 2005
87
Seattle
Yes, there's also the 'dog leg' transmission where reverse is where 1st gear should be. And first gear is located where 2nd gear should be. That doesn't necessarily mean it's got helical or straight cuts. It could be either. Confused yet?:)
