The ecu will take care of the low throttle. ..butwith big cams u and injectors u will have to pull fuel at a idle to get it tto go closed..Turbo Habanero;1877768 said:Ne points are going to be unique to where you need tuning also the throttle percentage for the high map i set 74%-75% i would not touch the low map as it will mess with the closed loop the ecu will take car of this.
I pull 8 percent at 1k on the low to get the car to go closed loop
