would this be sacreligious?
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Just a thought...but if you were to drop and LT1 350 w/ aluminium heads, and use modern gm fuel injection and of course turbo hydro trans (which would make the swap a lot easier than trying to mate a toyota trans), you my friend would have a hell of a daily driver. Any weight gain would be negligable , if there is any weight gain at all.
Side note: If it were me I would keep that puppy looking as bone stock as possible on the exterior. What a sleeper!:eek3dance
boogum7
Oregon
my brother has an LT1 w/ aluminum heads in his jeep, with an exhaust cutout :love: (so freaking loud at WOT). His jeep weighs in at 5,000+ pounds and the LT1 makes that thing move very well still. So it would do very well in a supra.
iwannadie
981
gilbert, az
I dont know much about american muscle motors. However, a friend at work is in the middle of swapping a 305 motor I think, out of a camero into his chevy s10 pickup. Sounds like a sweat idea to me putting that much power into a small truck.
Hes been working on it for a few years now, its a slow and long money sucking proccess if Ive ever seen one!
Reaper Man
I'm the responsible one
Jun 10, 2007
80
MA
sounds interesting. It'd be interesting to see just how much you have to fabricate and mod the shell to get everything to work. Though different, it might not be "smart" if that makes sense
AJ'S 88NA
2,419
Florida
zurud said:
GM 305 sucks. NA 7m motor make 10hp more. If you want v8 put sbf or sbc.
The 5.0 H.O. is a Chevy SB. I had a Z-28 with the H.O. not but I think 1 or 2 years bebore they changed to the IROC Z-28's. Underrated from the factory HP. Ran very well stock.
Jo3f1sh
Noob
Jul 30, 2007
71
Dallas, TX
There were a few variations of the Chevy 5.0 305 V8. It came carbureted (horrible rochester carburetion), throttle body injection (top mount throttle body with injector jets) and TPI (tuned port injection - true EFI). The third being the best setup. BUT, even the best 305's in the Camaros/Firebirds only developed around 215-230HP. For a big hunk of iron, that's not all that great. I also haven't seen many that respond well to mods. For the best bang for the buck, many guys just swapped to a 5.7 350. They're basically a dime a dozen and can be built so many different ways with great results.
Ford 5.0 302 V8's are another story. These things are bullets out of the factory paired with a T-5 or any other stick transmission, and with a few things here and there, are VERY strong motors.
So basically, 5.0 305's aren't BAD motors...just not something i'd spend money on really...i'd swap in a Ford 5.0 or a Chevy 350. Just my $.02.
shaeff
Kurt is FTMFW x2!!!!
11
Around
go for it, and don't cut corners. (then build the 7m and put it in a foxbody stang!)
mwhahahah...
-shaeff
LT1 in a MKIII doesn't work so well...
TPI 305 does (you are all forgetting the amount of torque the TPI motors have), and even better if you port the TPI system (or use the better edelbrock pieces) and run a 350 with the system...
also, a 305 and a 350 are the same block....
still think an LSI would be the best bet, has the same great high redline as a 7M, and a huge powerband. Not to mention the aftermarket support for it...
