Nick, just an interesting tidbit from today.
Like a dumb@$$ I didn't do a process of elimination, only due to all three things happening at once.
I changed the air filter today to a new K&N. While doing so:
-I finally cleaned the wires off the water temp sensor plug. I then found a junk harness in the shop and snip snip wire wire - Vialo! New plug on the water temp sensor
-I noticed that the last owner of my lexus afm has cut part of the screw off. Almost the entire passage of the lower part of the afm housing was clear. I screwed it all the way in. Now there is rougly 1/4" of clearance in the lower passage.
The stalling issue has reduced in frequency, although its still there.
Also, the AFR durring idle is now 15.8 ~ 17.1
Cruise is around 14.1 ~ 15.2
Also, Jet Im not ignoring you on your posts or your sugestions, but simply I have a lack of knowledge on the eletrical items such as testing the IDL circuit. So, Im starting off with the simple stuff first (simple to me, or more mechanical Im not sure).
