yeah justin, I wanted to tell you about it....haha...
I just put the cometic I got from you in when the head was off, and used brake quiet on it this time. I also relapped my block and checked the head surface. Everything appears to be good. If this one is going to blow, oh well....I hope it holds until I get my new motor finished. I'm going all out on the new motor, with the head and block being cut and finished for an HKS style metal head gasket.
This is going to be the specs for the new engine:
block decked and head shaved
HKS Metal Head Gasket
ARP Head Studs
ARP Rod bolts
ARP Main bolts
ARP Flywheel bolts
.17 over Ross Forged Pistons
Aftermarket Rods(not sure what type yet, as I haven't ordered yet)
7M Crank, fully balanced, Nitrided and Polished
Possibly 1mm oversize valves, if funding allows
Ferrea Valve Springs and locks
Possibly Shim under bucket conversion
Possibly Comp custom ground cams
Coil on plug ignition
FFIM with larger throttle body
ACT pressure plate with HP 6 puck Bronze disk
GT3540R Turbo
The Biggest intercooler I can fit behind the front bumper
2.75 inch intercooler piping
Fidanza Flywheel
3.5 inch exhaust
I already have my block and crank prepped, and a good many of the parts either on order or in the shop. So hopefully this engine will hold out till then on CT power, then I can have the real motor in...
