well finally got to the last chapter of my build, getting the engine running. i have everything hooked up. im getting fuel, all the injectors are about 2.8 ohms. im getting spark in all 6 cylinders. timing is set at 0* on the crank pulley, both cams are lined up w/ the marks, and CPS was set per TSRM. when cranking the tach jumps so im led to believe the CPS isnt the culprit. sometimes i get a bang out the exhaust mani but not like its trying to start, just a single bang (has only happened 3 times in the last 2 days.)
checked for codes but the CEL doesnt even blink.
im getting pretty frustrated now as the weather is really improving and damnit i wanna cruise around w/ the top off!!!!
any help is appreciated. thanks!!!
~rick~
~rick~
