I am new to the supra, I have mainly tinkered with V8's in my nova. Saw one of these supras and wanted to fix one up. I drove over to Niagara falls, NY from vermont to pick a 87 supra. The supra had a manual boost controller for a mod and that was it. Boost turned up high I thought for a stock fuel and air system. Boosting up to about 18 lbs which was at 4000 rpms and would I assume fuel cut. I drove it home babying the car because I did not think it would be safe to try and hammer on yet. I got home parked the car, and tried to start the car and it would not idle. I took the afm off my other car that ran fine until the head gasket blew. After installing that afm the car would start but would cut out in nuetral at 2700 rpms. Vehicle is responsive until rev goes beyond 2700 rpms. Also the idling is rough. I thought maybe it would be the tps and I changed that, calibrated it with a multimeter and it still wont idle. I then replaced the isc and still wont idle. At the same time this issue occured I started to hear a ticking which sounds like a valve. Not sure motor only has 1500 miles on it. I am stumped, check engine light is not on, and I cant figure it out. Any help would be greatly appreciated.
