I have an 7mgte that was originally automatic and i would hit fuel cut at 13 psi with just 3 inch exhaust Walbro 255 and intake. Did a tranny swap and immediately it would only boost to 7 lbs. Checked for leaks have none, tried 2 different wastegate actuators, same problem.
With boost controller i can spike to 17-18 but it will go down gradually and its slow as shit.
*This problem was happening before mods and after.*
Current mods now:
550CC injectors
Lex afm
3 inch
Intake
Walbro
Stock IC
I was wondering since it started right after the swap, could it possibly be because i had to leave the auto gear selecter in neutral instead of park or vice versa?
Current mods now:
550CC injectors
Lex afm
3 inch
Intake
Walbro
Stock IC
