Wiseco Vs. CP Pistons
  • Total voters
927mgtepat
653
Brighton, MI
Just wondering out of these two piston companies, Wiseco and CP what pistons do you like better. Is there really a difference between the two besides name and price. In the next week I'm going to buy a set of pistons but cant decided.
:naughty:
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Weights, skirt length, dome, things like this are what you need to pay attention to when deciding on what you want. Check out each manufacture's website for the details on their pistons, then make your comparisons. You would typically want a light weight piston with shorter skirts for racing, and a heavier one with longer skirts for daily driving, longetivity, and be able to withstand a tune gone bad.
H
HPF Kyle
Guest
Wiseco's are great because most of the time they come with rings as well. :)
-Kyle
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
If you haven't already found out.. I believe you will only find the CP's in .40 and the Wiseco's have a 9:1 compression. If your not concerned about either then it's a toss up. Suprarich in the vendor section has pretty good pricing on the JE's. I bought a set and sent them to Swaintech for coatings. The coatings were about $220 or so for the crown and skirt.
turbogate
Life is Boost
May 18, 2005
425
South, FL
bigaaron said:
CP is a little bit higher quality piston then the Wiseco, but it costs more.
True dat. This guys in miami who builts high budget race engines and believes in CP pistons. He told me that CP was created by an Ex JE employe who went his seperate way, thing is, he was the brain behind JE pistons. Dont know how accurate that is though
Doward
4,245
Alachua, FL
The fact that the Wisecos are only .160" under the dome, scares me.
I think the Wisecos would have a lower tolerance of detonation - but still stronger than stock, so don't think the Wisecos are weak, by any means!
I, personally, would go with the CP vs the Wisecos.
Justin727
T-virus infected
There are a few reasons why I chose Wiseco over Ross and one of the main things was the fact of the wiseco's having a longer skirt then the ross and I didnt want loud piston slap.
Although u can hear piston slap with wiseco's faintly, its not nearly as bad as Ross and JE's
