Wiring the 2jz into the ma70 chassis
Dirgle
Conjurer of Boost
Pauma Valley, CA
First let me say this, what you see below is a half finished project. I had originally planned to include wiring for both MKIV/Aristo 2JZ-GTE's in to both the pre and post 89 chassis. But I never reached a point where I felt comfortable with the way the info was edited and presented. I wanted something that was easy to read and understand by someone with a little electrical knowledge. After several failed attempts I shelved the project till later. What you see below is essentially scraps put together from one of my better attempts. It could be better but if I don't put it out here now, it may never be. What follows is the culmination of countless hours picking through the info on arnout's site supras.nl, much time in between the pages of an 89TSRM, a 87 Supra EWD, 95 TSRM, and a 93 GS300 EWD.
I would also like to state that this information is presented here for research purposes. My recommendation, for a well built fully functioning swap harness is to contact drtweak and get one from him.
________________________________________________________________________
This is for swapping a 1st gen Aristo 2JZ-GTE into a pre89 MKIII
How to read: The first part deals with the connectors that are present and their associated pinouts. So you know what they do and can decide if you want to keep them. For example pin 6 thru 8 on Connector 'C' deals with the traction control and can be deleted.
The second section titled 'Connections' deals with the the hybrid connections that need to be made between the 2JZ harness and the MKIII harness. Three connectors from the 7M main engine harness are required to be spliced in to the 2JZ harness.
M1
Pin # 1 – Reverse Light Power from Switch ((R-B) Also power for A/T indicator/neutral start switch)
Pin # 2 –Reverse Light power to Switch(Y)
Pin # 3- Speed sensor from combo meter. (ECU/P <->Body/Y-R)
Pin # 4 &#8211;Tach Signal (B)
Pin # 5 &#8211;Turbo Indicator light(Outside U.S.)
Pin # 6 &#8211;Ground(MASS) for Combo Meter (BR)
Pin # 7 &#8211;Oil Pressure Signal for Combo Meter (Y-B)
Pin # 8 &#8211;Check Engine Light &#8221;W&#8221; (GR-G)
Pin # 9 &#8211;Water Temp Signal for Combo Meter (Y-G)
Pin # 10 &#8211;Defogger Relay (V)
B1
Pin # 1
Pin # 2 - *A/T Only* &#8216;L3&#8217; Signal from ECT ECU to TCCS (R-W)
Pin # 3 -* A/T Only* &#8216;L2&#8217; Signal from ECT ECU to TCCS(R)
Pin # 4 -* A/T Only* &#8216;L1&#8217; Signal from ECT ECU to TCCS(B)
Pin # 5 &#8211; &#8216;E2&#8217; Signal on Diag Block(B-R) used to monitor fuel pump voltages
Pin # 6 &#8211; Ground to activate Fuel pump relay (G) Normally the ECU grounds, Ground to MASS for swap
Pin # 7 &#8211; *A/T only *Power for secondary coil in circuit opening relay(B-L)
Pin # 8 &#8211; Fuel pressure down. If this wire is grounded, voltage to the fuel pump is reduced (Y)
Pin # 9 &#8211; Power to Circuit opening relay for Fuel pump (B-R)
Pin # 10
Pin # 11 -*A/T Only*Neutral signal for ECT ECU (W)
Pin # 12 &#8211; &#8220;Start&#8221; signal from relay to starter (Engine/B-L <->Body/B-W)
Pin # 13 &#8211; Signal from A/C amplifier (L-R)
Pin # 14 &#8211;From Diag Block to test for TEMS Hard mode (V)
Pin # 15 &#8211;Cruise Control Clutch Switch (B-Y)
Pin # 16 &#8211;IG switch power to ECU(B-O)
Pin # 17 &#8211;Power from Ignition switch IG2 (B-O)
Pin # 18- Signal from theft computer to theft deterrent horn (Y-L)
Pin # 19 &#8211;From Headlight relay(R-Y)
Pin# 20 &#8211;injector signal to Super Monitor (W-L)
Pin # 21 &#8211; &#8216;T&#8217; Signal to Super Monitor(R-G)
Pin # 22 &#8211; From Super Monitor computer to ground(MASS) (BR)
C1
Pin # 1 - Batt signal from 15A EFI fuse (B-Y)This source is taken before the EFI main Relay
Pin # 2 - M-Rel coil signal from ECU (B-O) This is the signal that the ECU sends to activate the EFI Relay
Pin # 3 &#8211;Source from 15A HAZ-HORN Fuse to Theft Deterrent horn (W)
Pin # 4 &#8211; Batt+ from EFI main relay (via 15A EFI) (B-R)This source taken after the EFI relay
Pin # 5 &#8211;GND signal from the EFI relay coil.(W-B) This signal goes to the Diag Block &#8216;E2&#8217;
Pin # 6
Connector C
Pin # 1 &#8211;Aircon lock in signal (GR-R)
Pin # 2 &#8211;Aircon SG for Lock in (GR)
Pin # 3 &#8211;Throttle Actuator for Trac System (W)
Pin # 4 &#8211;Throttle Actuator for Trac System (R)
Pin # 5 &#8211;Aircon Clutch signal (B-W)
Pin # 6 &#8211;Throttle actuator for Trac System (B)
Pin # 7- Throttle actuator for Trac System (G)
Pin # 8 &#8211;Throttle actuator for Trac System (Y)
Pin # 9
Pin # 10
Pin # 11 &#8211;Throttle Actuator for Trac System (L)
Pin # 12 &#8211;Throttle actuator for Trac System (GR shield)
Pin # 13 &#8211;Oil Valve for Hydro Fan (L-Y)
Pin # 14
Pin # 15 &#8211;FP signal for Check Box
Pin # 16
Pin # 17
Connector D
Pin # 1 &#8211;Oil level light (Y-R)
Pin # 2 &#8211;A/T control pin 8 (R-L)
Pin # 3
Pin # 4 &#8211;AB Check Signal (B-Y)
Pin # 5 &#8211;TEM Check Signal (GR-R)
Pin # 6
Pin # 7 &#8211;WA Check Signal (P)
Pin # 8 &#8211;CCO Check Signal (GR-B)
Pin # 9 &#8211;Oil Valve for radiator fan(pressure driven)(B)
Pin # 10 &#8211;OP1 check signal (P-L)
Pin # 11 &#8211;WB Check Signal (P)
Pin # 12
Connector E
Pin # 1
Pin # 2 &#8211;&#8216;W&#8217; (warning) Check Engine Signal (diagnostics box)(B-Y)
Pin # 3 - +12Volt for electronic controlled transmission (B-R)
Pin # 4 -A/T neutral start (pin 6 on tranny)(B-Y)
Pin # 5 &#8211;A/T neutral start (pin 5 on tranny) (B-W)
Pin # 6 &#8211;Tc Check Signal (Diag Box) (Y-B)
Pin # 7 &#8211;TE2 Check Signal (Diag Box) (L-B)
Pin # 8 &#8211;&#8220;N&#8221; Signal from A/T indication switch for dash (G-R)
Pin # 9 &#8211;&#8220;2&#8221; Signal from A/T indication switch for dash (G-O)
Pin # 10 &#8211;&#8220;L&#8221; Signal from A/T indication switch for dash (G-B)
Pin # 11 &#8211;&#8220;D&#8221; Signal from A/T indicator switch for dash (G-W)
Pin # 12 &#8211;&#8220;P&#8221; Signal from A/T indicator switch for dash (G-Y)
Pin # 13 &#8211;&#8220;R&#8221; Signal from A/T indicator switch for dash (R-B)
Pin # 14 - +12Volt for A/T indication switch and backup lights
Connector F
Pin # 1 &#8211;Signal for Starter (B)(FAT)
Pin # 2 &#8211;SPD signal from speed sensor (pin 3)(L-R)*Delete if Auto Removed*
Pin # 3 &#8211;SPD signal from speed sensor (pin 2)(L-Y) *Delete if Auto Removed*
Pin # 4 &#8211;TE1 Check Signal (Diag Box)(L-W)
Pin # 5 &#8211;TS Check Signal (Diag Box) (G)
Pin # 6 -+12Volt for igniter ect. (B-O)
Pin # 7 &#8211;Ground (BR)
Pin # 8 - Signal for Oil Pressure Gauge (Y-B)
Pin # 9- Signal for Water Temp gauge on Combo Meter(Y-G)
Pin # 10 - VF1 Check Signal(Diag Box)(G-R)
Pin # 11 &#8211; Ground (BR)
Pin # 12 &#8211;RPM Signal (B)
Pin # 13
Pin # 14
E10
Pin # 1 &#8211;&#8216;IGSW&#8217; Ignition Switch signal from IG2 (B-O)
Pin # 2 &#8211;&#8216;SPD&#8217; Speed signal (V)
Pin # 3 -
Pin # 4 &#8211;&#8216;STP&#8217; Signal from stop light switch(G-W)
Pin # 5
Pin # 6 &#8211;&#8216;W&#8217; Warning lamp indicator (B-Y)*CEL light*
Pin # 7
Pin # 8 &#8211;&#8216;R&#8217; Indicator Light(R-B)
Pin # 9 &#8211;&#8216;2&#8217;Indicator Light(G-O)
Pin # 10 &#8211;&#8216;L&#8217; Indicator Light(G-B)
Pin # 11
Pin # 12 &#8211;&#8216;OD1&#8217; From Cruise control ECU(V)*ECT signal*
Pin # 13
Pin # 14
Pin # 15 &#8211;&#8216;ELS&#8217; Idle-up signal from defogger relay(LG-B)
Pin # 16
Pin # 17 &#8211;&#8216;TT&#8217; Signal for Data Link connector 2(LG)
Pin # 18 &#8211;&#8216;P&#8217;ECT Pattern select switch
Pin # 19 &#8211;&#8216;TE2&#8217; Signal for check connector(L-B)
Pin # 20 &#8211;&#8216;TE1&#8217; Signal for check connector(L-O)
Pin # 21 &#8211;&#8216;DI&#8217; Control Signal from Fuel Pump Computer(LG-R)
Pin # 22 &#8211;&#8216;FPC&#8217; Control Signal to Fuel Pump Computer(G-R)
Pin # 23 &#8211;&#8216;ACMG&#8217;Signal From magnetic clutch relay(W)
Pin # 24 &#8211;&#8216;M-REL&#8217; Signal to activate the main EFI Relay (G-O)
Pin # 25
Pin # 26
Pin # 27
Pin # 28 &#8211;&#8216;OD2&#8217; From O/D select Main Switch(B-R) *ECT signal*
Pin # 29
Pin # 30
Pin # 31 &#8211;&#8216;+B&#8217; 12volt signal taken post-EFI Relay(B-R)
Pin # 32 -&#8211;&#8216;+B1&#8217; 12volt signal taken post-EFI Relay(B-R)*spliced into same line as &#8216;+B&#8217; pin 31*
Pin # 33 &#8211;&#8216;BATT&#8217; constant 12Volt signal taken pre-EFI Relay(W-L)
Pin # 34 &#8211;&#8216;A/C&#8217; From A/C Lock amplifier(B)
Pin # 35 &#8211;&#8216;PS&#8217; Signal for power steering pressure switch(G-Y)
Pin # 36
Pin # 37 &#8211;&#8216;TR&#8217; From Trac Control Computer (P)
Pin # 38 &#8211;&#8216;NEO&#8217; From Trac Control Computer (BR-W)
Pin # 39 &#8211;&#8216;VT02&#8217; From Trac Control Computer(Y-R)
Pin # 40 &#8211;&#8216;VT01&#8217; From Trac Control Computer(P-L)
Connections
M1
Pin #1 - This branch should be transplanted from the 7M harness. Line from (M1 pin 1) to (B pin 1) should be preserved *see appendix for connector &#8216;B&#8217;
Pin #2 &#8211; This branch should be transplanted from the 7M harness. Line from (M1 pin 2) to (B pin 2) should be preserved *see appendix for connector &#8216;B&#8217;
Pin #3 &#8211;&#8216;SPD&#8217; -> E10 pin 2
Pin #4 &#8211;&#8216;Tach&#8217; -> IK1-F pin 12
Pin #6 &#8211;&#8216;MASS&#8217; &#61664; MASS(Ground)
Pin #7 &#8211;&#8216;Oil Pressure&#8217; ->IK1-F pin 8
Pin #8 &#8211;&#8216;W&#8217; -> E10 pin 6, IK1-E pin 2
Pin #9 &#8211;&#8216;WATER TEMP&#8217; -> IK1-F pin 9
Pin #10 &#8211;&#8216;Defog relay&#8217; -> E10 pin 15
B1
Pin #5 &#8211;&#8216;FP Voltage&#8217; ->IK2-C pin 15
Pin #6 &#8211;&#8216;FP Relay Ground&#8217; -> MASS(Ground) *see Appendix
Pin #9 &#8211;&#8216;12V for COR&#8217; ->C1 pin 4
Pin #12 &#8211;&#8216;Start&#8217; -> IK1-F pin 1
Pin #13 &#8211;&#8216;A/C Amplifier&#8217; E10 Pin 34
Pin #15 &#8211;&#8216;Cruise Clutch&#8217; ->E9 pin 76 *see Appendix
Pin #16 &#8211;&#8216;IGSW&#8217; ->E10 pin 1
Pin #17 &#8211;&#8216;IG2&#8217; -> IK1-F pin 6,
C1
Pin #1 &#8211;&#8216;Batt&#8217; ->E10 pin 33
Pin #2 &#8211;&#8216;M-REL&#8217; -> E10 pin 24
Pin #4 &#8211; &#8216;+B&#8217; -> E10 pin 31,32
Appendix
Connector &#8216;B&#8217; is located at the R154 transmission and is used for the reverse light switch,
and is transplanted for this swap.
Fuel Pump Relay
To activate the relay the 7M TCCS normally grounds pin 6 of connector B1 when the ECU see an RPM signal. This is a safety feature so the fuel pump will stop if the engine stops, if something like an accident were to happen. The 2JZ ECU does not do this and has a separate computer to accomplish this task. At the moment I&#8217;m not sure how to swap that computer over. So unfortunately the simplest solution is to physically ground the wire from B1 pin 6. This allows the fuel pump relay to kick on whenever the ignition switch is turned on. However this disables the rpm triggered safety feature. Hopefully I&#8217;ll come up with a better solution in the near future.
E9 Connector
Due to the limited pins that have to be messed with on this connector I decided to leave the pin out off the main pin out. Simply reference the pin numbers from above.
Acronyms
FP &#8211; Fuel Pump
COR &#8211; Circuit Opening Relay
TCCS &#8211; Toyota Computer Controlled System i.e the ECU
SPD &#8211; Speed
IG - Ignition
MASS-Chassis Ground
*All connections shown in red are the bare minimum necessary to start the engine. Just to test if the motor functions.
Dirgle
Conjurer of Boost
Pauma Valley, CA
You should have two connectors on your Aristo ECU a larger one that has two parts and a screw in the middle, and a smaller one. If your ECU is missing either of these plugs then yes you will need to source one.
S.A. supra
2,405
Buda, Texas
how do you wire the a/c? dirgle in your right up you only have 1 wire wired up for the a/c. does your a/c work? anyone wire up there a/c from aristo harness into a mkiii?
IBoughtASupra
4,455
Queens, NY
The AC in the MK3 does not run off the computer, nor would it need to be controlled by the computer.
Look at the pinout for the 7M computer for your year of Supra. The A/C is just to let the computer know to bump up the idle when the A/C is one, that's all.
The A/C system is controlled by a little black box located right by the computer and I believe it is called the A/C amplifier but I am not to sure on that. I was worried about going standalone and not having the A/C work but on my 1JZ, it works fine.
Which means, just take the wire that signals for idle up to the 7M computer(use the pinout) and put it to the corresponding pin for the Aristo computer that is responsible for idle up.
Dirgle
Conjurer of Boost
Pauma Valley, CA
IBoughtASupra is correct, and the system will work fine that way. It's the way it was designed to work with the 7M. Like the pinout says, connect pin 13 of B1 to pin 34 of E10.
However, the 2JZ ECU has the ability to deactivate the A/C clutch under full throttle conditions so that no power is parasitically being drawn off buy the A/C system at that time. And there is a way to wire that feature in to the MKIII, but I wanted to test it first, to be sure, before I put the information out there. Unless somebody else has done it and can comment on it.
Until then I would just connect it the way shown in the pinout above.
S.A. supra
2,405
Buda, Texas
Ok but when I cut the aristo body plug it has the three wire that run to the a/c on it g (aircon sg for lockin)b and w (aircon clutch signal)and r and g (aircon Lock in signal). So basically the a/c has no wire hooked up. Where do those wires go?
Dirgle
Conjurer of Boost
Pauma Valley, CA
Your right, it seems I did leave that off of there.
Now, which A/C compressor do you have on there the 7M one or the Ariso one with the 7M head?
If its the Aristo one, you actually only need one of those wires. The B-W coming from connector 'C' pin 5. the other two are not used on the MKIII A/C system.
And it needs to be connected to the single wire that originally went to the 7M A/C clutch( L ), located on the driver side fender.
If you used the 7M compressor then just connect the one wire to it like before and its ready to go, no need to deal with the three wire from the Aristo A/C system.
S.A. supra
2,405
Buda, Texas
I'm going aristo.
Ok to make sure I get this staight. The B1#13 to the E10#34 then run the black and white from the from the A/C compressor to the blue wire next to the battery fuse box.
Is this the plug?
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
S.A. supra;1748633 said:
I'm glad I don't have pps, and deleted my abs.
i have no ps either but i have abs and a sensor is out at the moment so its not working. but in my gfs supra it has abs and ps. i like the abs in our cars
PPs and abs you simply take the wiring out of the 7m harness and insert it into the jz harness. No soldering or cutting needed.
Dirgle
Conjurer of Boost
Pauma Valley, CA
S.A. supra;1748572 said:
I'm going aristo.
Is this the plug?
Yes on the first part and no on the second, but you're close. It's a single pin female connector with two blue wires going into it. It should be near there.
Dirgle
Conjurer of Boost
Pauma Valley, CA
I'm not familiar with f1 or f2, however it does uses two different connectors, but the only difference is color, one is grey and one is brown. And Toyota only offers the grey one now.
The part numbers are:
90980-11154
90980-11284
I'm not sure which one is still active, but if you go into Toyota they can tell you which one still exists in their system.
