Wiring the 1UZ-FE into a Pre-89 Supra
CheesePhantom
Tampa, FL
Chambers;1903242 said:
No extra grounds that I'm aware of. In the dash, is your Black-Orange wire from pin 16 on B-1 connected to the Black-Orange wire from pin 11 on IJ2? That wire comes from your ignition switch, when its tuned to the on position it tells the ECU to kick the EFI-Main relay on, without it the engine will not run. Pre-96 1UZ igniter and fuel injectors get their power from EB2 in the engine bay. 96 and up igniter and fuel injectors get there power from IJ1 at pin 3 and pin 7 both Black-White color, in the dash.
Yup. I made a patch harness between the two, using 7M Harness connectors and SC400 body connectors.
I have like five wires connected to the Black-Orange wire, including:
- The fuel pump, which I've wired into a separate 30A relay; utilizing the 12 volt mod.
- The Black-Orange wire from IJ1
- Both Black-White wires from IJ1
- The yellow fuel pump relay wire from B-1, which has become obsolete
I've also made patch harnesses to merge EB1 and EB2 into the MA70 body harness/Fuse box.
I'm at a loss, man. I've looked over my wiring a million times and I can't find a reason why the ECU isn't kicking on. I could understand if the EFI Relay went bad, since the car sat for three years, but wouldn't the ECU still turn on (CEL at on position) with a bad EFI Relay?
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
Looks like you did a nice job on your swap harness. If the EFI main relay does not kick on then the ECU will not see any power. Pull the relay and test it. I had an 89 that wouldn't kick the EFI main relay turns out the ignition switch went bad, one of the terminals corroded and fell apart. That caused the 7.5a IGN fuse to blow, witch ultimately kept the ECU from getting power. Something to consider. Right now I suggest looking over your engine bay wiring.
CheesePhantom
Tampa, FL
Thanks a lot, man; for the compliment and for the advice. I will test the EFI Relay and take a closer look at my engine bay wiring as soon as possible.
CheesePhantom
Tampa, FL
Thank you, 4U2QUIK; and thanks again, Chambers. I started up my car for the first time today; as it turns out I made a mistake with the engine bay wiring. It's all fixed now.
[video]https://www.facebook.com/v/10151342644029547[/video]
White Zombie
272
Hampton , VA
in your earlier post you were asking if the diagram had wiring for a cold start injector . I thought that was only on the pre 92 models, aka the LS400 ? Im buying a 1990 ewd for a 1990 ls400 . Only because that happens to be the Ecu and wire harness i currently have.
im still using a sc motor/ oil pan and all, just dont have the wiring ecu for it .
SupraPieces
157
New Jersey
www.facebook.com
Is there a drawing of how to wire the fuse box connectors or is that on the first page? My 1UZ came with a cut harness and no ECU so I have to do a lot of detective work to figure out what year my motor is and which plugs and ecu I need... anyone have any tell-ale info for me to verify what year mine is?
I will post some pictures if needed
Chambers
Now you know
Sep 9, 2007
983
On the SC harness the plugs are the same 92-97, after that it gets a little fuzzy. I havent dealt with anything newer than the 97 EWD book and an actual 96 harness.
You will need dash plugs (5 total; 4 needed) IJ1, IJ2, IK1, IK2, and II1 if you want to control your heater valve. In the SC they are a PITA to get to/out but its possible withoud removing the dash. In the engine bay you only really need EB1 and EB2, In the SC its located on the front of the fuse box.
The diagram at the bottom of the first post shows the EFI wiring layout in the engine bay (fuse box), the starter goes through EB1 but its not on that schematic.
Chambers
Now you know
Sep 9, 2007
983
Just added a new wiring diagram to post 1:
1987 Supra to 1993 LS400 1UZ-FE (This diagram is subject to change, since I have not done a LS400 1UZ-FE swap yet it may change as others give me input)
