After battling the wire gremlins, I am starting over with the documentation and making sure that the connections match. Can you guys take a look and help verify? I will use this tomorrow to rewire and verify everything. There may be mistakes, since I've been cutting and pasting from several sources (which may have been wrong). I've gone through and double-checked the info below. Let me know what ya think and maybe we can finalize it for others to use.
E9 & E10 ECU Connector info -
http://supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
Aristo body plug (is really 4 separate connections in one - C, D, E, & F) -
http://www.g099521.net/MKIII/2JZ_SWAP/pinout_test.xls
1JZ Reference docs from Rick's site (zipped) -
http://www.g099521.net/MKIII/2JZ_SWAP/ea21989.zip
1991 Auto to 2JZ/R154 (Aristo ECU/harness)
M1 PLUG:
Pin #1 R/B wired to W at tranny connector (Reverse lights).
Pin #2 Y wired to B at tranny connector (Reverse lights).
Pin #3 Pink to E10 Pin #2 Pink (SP1, no 1 vehicle speed sensor from trip/odo meter)
Pin #4 B to E10 Pin #16 B/W (Taco, Tachometer signal)
Pin #5 not connected
Pin #6 wired to aftermarket sender?
Pin #7 wired to D Pin #1 Y/R (oil level - Body plug) - Will rewire using 7M sender
Pin #8 not connected
Pin #9 not connected??????? ("W" signal for check engine)
Pin #10 to Pin F9 Y/G (Water temp sender for combination meter) - Aftermarket sender
Pin #11 wired to E10 Pin #15
B1 PLUG:
Pin #1 not connected
Pin #2 not connected
Pin #3 not connected
Pin #4 Green to Pin #29 (C15 – G/W) body plug – FP signal to diag (currently have this grounded so that pump comes one when key is on)
Pin #5 B/L to E10 Pin #31 on ECU connection - A/T coil for circuit opening relay
Pin #6 Y not connected
Pin #8 NSW to cruise control clutch switch (MT)… Don’t have?
Pin #7 R/B to E10 Pin #32 on ECU connection - Plus for circuit opening relay
Pin #9 B/O to E10 Pin #1 on ECU connection - Ignition switch
Pin #10 B/W to Pin #54 (E4 – B/L) body plug - to neutral st. switch
Pin #11 Idle Up signal from A/C amplifier --- Needed? Where to connect?
Pin #12 Theft deterrent horn signal --- Needed? Where to connect?
Pin #13 A/C water temp switch --- Needed? Where to connect?
Pin #14 B/O to E10 Pin #1 on ECU connection
Pin #15 SPD signal for cruise control --- Needed? Where to connect?
B2 PLUG:
Pin #1 Airbag signal check connector --- Where to connect?
Pin #4 R/Y to E10 Pin #15 on ECU connection
Pin #6 Violet to D Pin #5 body plug Grey/red (not needed?)
Pin #7 W to E9 Pin #76 on ECU connection - 'N' signal from A/T indicator S/W
Pin #20 Y/L to E9 Pin #64 on ECU connection - IDL
E10 & C1 PLUG:
Pin #24 to C1 Pin #2 (Black/Orange - M-Relay)
- Body plug has two black/orange wires going to one pin. Soldered them to the big fat wire coming from plug B1 Pin #14
Pin #31 Black/Red = B+ (Connected to C1 Pin #4 & B1 Pin #7)
Pin #32 Black/Red = B1+ (Soldered to C1 Pin #4 & B1 Pin #7)
Pin #33 W/R C1 Pin #1 (Black/Yellow = BATT)
