Wiring harness
supraken
47
pensacola, FL
I just rebuilt a 7mge and i dont know what order the wires from the wiring harness connect to the fuel injectors (what order) any info or pictures would help thanks
castrol supra
Semper Fidelis
May 8, 2008
95
The Back 9.
It's gray and green on my 91.
It's like reading only in reverse. Lay the harness out and hook it up from the rear to the front.
You almost can't mess it up. If you do. You will notice before you get done with all 6.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
The lengths of the wires should be a good indicator as they are all progressively longer or shorter, pending where you start. I believe the TSRM also tells you what goes where. ;)
