can i use a 88 automatic turbo wiring harness on an 89 turbo 5 speed
aznboik1mva New Member Aug 20, 2009 328 0 0 Manchester,Ct Nov 15, 2009 #1 can i use a 88 automatic turbo wiring harness on an 89 turbo 5 speed
RotaryHead Gets beat up by Motors Aug 27, 2009 219 0 0 Tucker, Georgia, United States Nov 15, 2009 #2 Yes you can youll just have unused tranny wires
92nsx Supramania Contributor Sep 30, 2005 2,957 0 0 Clearwater, MN Nov 15, 2009 #3 Depends on if you have a early or late 89 (gray or yellow plug). And what ecu your going to use.
aznboik1mva New Member Aug 20, 2009 328 0 0 Manchester,Ct Nov 15, 2009 #4 im gunna use the 88 harness on the 89.
92nsx Supramania Contributor Sep 30, 2005 2,957 0 0 Clearwater, MN Nov 15, 2009 #5 aznboik1mva;1451396 said: im gunna use the 88 harness on the 89. Click to expand... We know that, you said that in the OP.
aznboik1mva New Member Aug 20, 2009 328 0 0 Manchester,Ct Nov 15, 2009 #6 lol..i though u were askin what ecu im gunna use...ma bad
92nsx Supramania Contributor Sep 30, 2005 2,957 0 0 Clearwater, MN Nov 15, 2009 #7 Again what harness is already in the 89? yellow or gray plug? As for the tranny, RotaryHead is correct, auto harness will work on a manual. You will just have some extra plugs that are not going to be used.
