wiring harness question
shadow8450
kingston ny
does anyone know if a wiring harness off a automatic turbo supra would work on a 5spd turbo from the same year as long as i change out the ecu. in advance thanks
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I've never done it myself, but from what I've read if it's a harness from the same year everything should plug back in except for the plugs that went to the auto tranny ;).
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
If you use the auto harness on a 5spd, you'll have some extra plugs from the auto. That's it. plugs right into the ecu without modification, plugs into all the sensors etc.
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
I also used an auto ECU and a W58 but you will have to splice the Neutral safety switch. I hate Neutrals at least with emenies you know where they stand.
