Alright. If I ever get a hold of a '89 + harness I will do more wiring Schematics. For starters use this.
http://92tealsupra.webs.com/early89harnesswiring.htm
Your green/red wire is useless unless you want a/c, once you know what color on your harness are the ones to run and start your car you'll be set. Hope the site provided will show you what you need. Any additional questions please post in the thread so everyone* can help you out. I am not on here much anymore, I just checked my PM's I had (9)
Note: if anyone needs to get a hold of me,
Nsinfamy@hotmail.com will be your best bet. It goes directly to my phone so I will get it within 10 minutes, instead of 3-4 weeks.
From the looks of your wiring I see a larger Black/Blue for your Starter Solenoid, and the other one is for,     A/T circuit for coil opening relay------------------------------------------Medium / Black Blue
I posted this site awhile ago if anyone needed help. What most people do not know! The way the Turbo harnesses work. Most think it is 87-88 and then 89-92, incorrect. They changed the pin outs on more then just two harnesses, it also depends on a lot of factors listed below.
The colors of the wires don't change much throughout the years. What changes the most is if your car has ABS, TEMS, Progressive power steering, Automatic transmission, and '90 + had air bags. The pre '89 has the different wires pinned differently, but the site I provided is for a early '89 so please
