I recently installed a set of rain-X latitude wipers on my Supra. Pretty much the same as the Bosch Icon blades as well.
The DS 19" is fine but the 17" passenger side blade does not touch the windshield in the center of the blade or on the far right edge about for about 2 inches, just on the lower half of the windshield. When it goes up the outside edge touches but the center still doesn't touch the glass throughout the stroke.
Only thing I can figure is the spring isn't strong enough on that side to make the wiper lay flat. It worked fine with the normal blades with 6 mounting points but not the new ones.
Anyone else have this problem?
Maybe I should get a replacement tension spring?
The rear blade works fine but it is also a 19".
