Will rod knock be confused with engine knock and send a signal to my computer to retard the timing? I just learned the sensor listens to determin knock based on sound. Also is there an audio recording of what engine knock sounds like?
joel w. said:
joel w. said:
No, but if Toyota was smart it would have. :nono:PorterzSupra said:Will rod knock be detected by knock sensor?
lagged said:no if you leave it unplugged it WILL throw a code. i know th.........
spipedong said:No, but if Toyota was smart it would have. :nono:
try splicing the two KS wires together and hooking just one up. Wouldnt this work?PorterzSupra said:I have a turbo computer and harness and NA block WHAT DO I DO WITH MY SECOND KNOCK SENSOR CONNECTION!??
