will not crank over... need help
mr. mk3
Fresno, CA
i just recently put in a new motor into my supra and i dont know why it wont start or even crank over. i double check all my wiring, ground, and plugs and they all look fine. they're all plug with no loose wires or plug. i bought new starter for it and still wont crank over or start. anybody know why or have this problem before? thanks for the help.
mr. mk3
Fresno, CA
ok.. i check all my fuses and all the fuse are fine... i bought new battery and starter.... yes there is power going to the starter and inside the car... all power is there.. i try jumping it and rechecking all my wires before i try to start it again and still it wont crank over..
mk3-4-me
669
Milwaukee, WI
Ya it could be the neutral safety switch... Try putting it in neutral and turn the key... I have to do that sometimes cause my linkage isn't adjusted right...
SC61 MK3
316
FL
test the wire going to the starter with a multi meter or run a wire from the battery and tap the starter wire to make it crank
