Ok I am starting to go mad.
I had a heat issue in the summer where the trans hump seemed overly warm but manageable. I figured I needed a trans cooler or something to deal with that.
Well a couple of weeks ago when the weather changed my supra developed an odd ping sound that increases under load when I give the car the gas. It does NOT do it in park or neutral. I changed the plugs and the #4 (4th from timing cover) spark plug was fouled somewhat. I also just realized that they didnt change the plugs when I had the BHG 2 years ago (go figure Priority)
What could this be? Its driving me nuts. The car has good boost (I am at stock until I figure it out) and power It revs good and idles fine along with good temp and oil pressure. I also changed the oil a bit before this started.
The ping sounds like when you run your fingernail over a comb. I also thought my exhaust sound was louder under the hood suddenly like I had a hole somewhere... I think I am just getting paranoid after seeing the posts about the EGR gasket..
V
V
