Widest tire on "sawblades"?
AcIdBuRn02ZTS
227
Indiana
Hey alls...
Just wondering what the widest tire that could safely be used on the stock 7.5" wide sawblades (88' model year)
Stock is a 225-50... so could one go much wider or would it be safe to do so?
-AcId-
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
245/50's for me. Only in the rear, stock size upfront. They fill the rear wheel wells very nicely.
JDMMA70
2,550
Houston
Anyone have any pics of the size difference of the 225's vs the 245's?
Did anyone see any noticble improvement?
Sawbladz
1,727
Oshawa, ON, CA
I would not go above a 245 on a 7 inch wheel. Any more than that and you are going well beyond the tire manufacturers suggested wheel size.
Jayhall
May 7, 2005
1,167
Surrey BC
This is exactly right!
225's
245's
TEMPEST
We're a work in Progress
Jul 29, 2006
27
New Orleans
I would do the 225/245 f/r combo, but you have to keep in mind the sidewalls. 225/50 and 245/50's will look kinda kooky, because the sidewall dimension is not the same for both. The sidewall is an aspect ratio, sometimes you have to try on a new pair of shoes to see if you like how they look. (OK so chickish,..I know! but check it out) On my MKII I had 225 fronts on 245 backs, same 60-14's but my car looked awesome!
Like a trans-am!
Cause the back was noticeably higher than the front. If that's your look? you're all set.
I had jacked up the rear end by ordering the same profile tires.(oh bye the way! don't go bigger than 225/60/14 and 245/60/14 on a MKII)not with stock shoes anyway.
Anyhoo, some of these guys are saying 265 on the sawblades.I'm always about bigger bein' better, However!
Just cut the sidewall,bye that I mean pay it some mind! to prevent possible rub.
And make sure your springs are up to it, your springs are VERY important.
I run 255/50/18's on my MKII in the back and they rub like hell.
Partly 'cause I should've run 245's, partly 'cause the Eibach springs I got are shit, too soft a spring rate.
Oh well, next time!
TEMPEST
