Widebands?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I used to run an LC-1 (Bosch sensor). It was a good little sensor. With the programmable outputs you could plug it into your stock ECU, and have it mimic a narrowband (you can re-program the output to have your car idle at a different A/F ratio on the stock computer if you like). It warmed up really quickly too. Good price, but doesn't come with a gauge. If you have a laptop, you can use that as a logging tool.
I currently run an HKS A/F knock amp (NTK sensor). It's super quick to react, very precise,and comes with a gauge (and also has engine knock monitoring built into it). You can input your own reference voltage to it, and have the output offset to match.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
Johnnieee said:
FJO all the way for me, its been great! Even the 5 wire O2 sensor is a Honda NTK replaceable part. :icon_razz
At a cost of $300 thru autozone. It's a VERY costly part, but a very accurate (laboratory accurate) and robust part. Much more tolerable to leaded fuel compared to the bosch sensor.
Luckily, I bought a new one when they weren't near as expensive as they are now. I even got it at cost when i ordered it. :)
tissimo
Stock is boring :(
Melbourne, FL
lm1
its large.. but at the time when I bought it, had the best datalogging (dont need now), mobility of any avalable(i use in friends cars all the time)..
still love it.. just wish i had a small display for it.. Might get a plx m300 to perminatly install in my car..
shaeff
Kurt is FTMFW x2!!!!
10
Around
innovate lc-1 + xd-16 gauge. :) bought it from dr. jonez.
-shaeff
