wideband
Supraboy89
357
Hampton GA
just need to know were i can get a good wideband. ive looked at driftmotions and suprasports. just want to know if there is any other places.
grimreaper
2,180
Dallas
get one that datalogs with rpms. Dynojet commander or zextronic come to mind. (the zextronics has quite a large add on capability for future tuning needs)
frontierguy25
968
TX
I just got a Zeitronix, and will be installing it. It will allow you to data log, your AF, tps, rpm, boost and egt. So you can look at a specific rpm and see what your tps and boost are doing compared to your AF and EGT. I've looked for a long time and I didn't want the AEM because it didn't data log and the innovative is really good and data logs AF but nothing else. That's why I got the zeitronix. Hopefully I get to use it next weekend.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Supraboy89;1343673 said:
when i install the o2 do i need to take out the stock one or drill and tap for the wideband
No, the stock one stays where its at. The W/B O2 should come with a bung, youll just need to make a hole and weld you new O2 to your Downpipe.
JPsToyota
231
East-Central, FL
If OP cant weld and you don't have a friend who can do it, you can take it to any exhaust shop and have them weld the threaded bung in to your exhaust for you. Then put the wideband in the bung. Bam, you got yourself a mounted wideband O2 sensor.
