WideBand installation
americanjebus
Mr. Evergreen
wa.
I have the xd-16 so it used the plug not the wires. do you have a laptop to hook up to the lc-1 and program your narrow band / wide band output?
blackkarma
MoN-sTaR
Jan 17, 2007
335
jacksonville, nc
americanjebus maybe u can help me from here......ok ive redone all the wiring every ground has its own single ground and im on the wideband brown wire.....from my calibration i took the O2 sensor out now do i need to cut the car completely on to do the calibration or does the O2 and the LC-1 just need power to do the calibration
americanjebus
Mr. Evergreen
wa.
http://www.innovatemotorsports.com/support/manual/LC-1_Manual.pdf
i Assume its this your reading.
Are the blue and white wires grounded to the same lug as the ground for the guage? They need to in order to avoid the signal "noise" described in the instructions on page 4.
I had the same issues getting this thing to work and everytime i did anything w/ the grounds i had to go back through the initial setup. Process is on bottom of page 8, i had to go through the entire process from beginning to end each time i did anything until i got the readout i was looking for. The sensitivity of the ground points is my only complaint w/ this system.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
blackkarma said:
yeah well after much configuring i singled out all the grounds and now its working flawless thanx for all the help
Congrats Brandon, now when you gonna come up to Havelock and get spanked? LOL.
Seriously though, give me a call, and lets hang out.
