here is my setup if this helps any:
1. Complete Engine rebuild
a. Shot peened and beam polished stock Rods.
b. 3 angle racing valve job on head.
c. Decked Block & Head
d. Bored out block .040 over
e. Installed all new gaskets, bearings, bushings, and etc.
f. Crank mangnufluxed, and balanced.
g. Built to withstand up to 29psi
h. Block & head cleaned
i. Re-assemble block and head
2. Polished head
3. JE Forged Pistons & rings
4. ARP Rod bolts
5. ARP Head bolts
6. Cleveite Race bearings
7. HKS 2mm Stop Bead metal head gasket
8. Fidenza Light weight fly wheel
9. Stage 3 RPS 6-puck racing clutch & heavy duty pressure plate
10. RC 550cc fuel injectors
11. APR adjustable fuel regulator
12. koyo radiator
13. Oil lines for turbo
14. K&N air filter system
15. Lexus VA Mass air flow meter and air Intake track
16. Turbo Inlet hose
17. Greddy Turbo Kit
18. Turbo outlet hose
19. HKS super sequential blow off valve
20. NGK plug wires
21. NGK platinum plugs
22. Unorthodox racing Adjustable timing gears
23. Unorthodox racing Under drive pulley system
25. dual flexalite fans
26. Custom upper and lower intercooler pipes
27. Perma-cool Oil Cooler
28. Perma-Cool Thermostat
29. Summit Racing Oil Filiter Relocation kit
Exhaust:
O2 sensor (bosh)
HKS 3” down pipe
HKS super Dragger 3” cat back exhaust system
Supra Store Cat eliminator
Sand blasting and cleaning of Turbo Outlet elbow Sand blasting and cleaning of Stock Exhaust manifold
