wich is the best intake cone filter for mkiii
92turbo4life
1,289
wherever
ok as you all know i have a 92 turbo
i need an intake because this shitty stock box sucks
i am looking at the k and n fpik or soemthing like that
i was wondering what everybody uses and what the best one is as far as performence and where and tear...?
all i have is a test pipe<3">
and a hks ssq bov
if that matters
but let me know as i want to throw a intake on
thanks
socc924
CT and Philly
I would go with the FIPK, cause thats what I have and im partial. Im not sure which one flows best, I would be willing to bet that they all are very close and you wouldnt be able to notice a difference between them. I prefer the K&N cause it never goes bad, just clean and re-oil it and you can use it forever.
N
NDBoost
Guest
actually some of your data is skewed. Infact the K&N filter was one of the lower scored filtering and air restriction filters out of the major companies.
Apexi rated the best airflow with the most amount of particle filtering. Just to let you know your nto supposed to OIL your filter, whenever you oil it that oil gets sucked onto the afm's components creating a layer that will in the end damage your afm.
Apexi's may be a bit expensive but they offer the best flow, and the best particle filtering without the use of oil. Just rinse them out with a light soap water solution and let it full dry before re installing.
tissimo
Stock is boring :(
Melbourne, FL
K&Ns you are suppose to oil.. to help with the filtering.. can be sucked into the afm and kill it, but usually if it does you used too much oil..
apexi is the way to go...... doesn't need oil, its a dry filter, flows good, filters good...
Silvasoup
143
Florida
I'm another Apex-I fan. They are supposed to be one of the best in filtering out dirt according to some past tests.
92turbo4life
1,289
wherever
okay so apexi-i is the name and it is basiclly the best flowing
and it doesnt need to be oiled becasue its dry
where is the best place to buy one
mkIIIman089
Ohio
NDBoost said:
:umno:
mvpmotorsports.com
hpf like was mentioned
suprasport
No matter where you get it unless its in stock somehow, is going to take forever... mine took months.
Jack
358
Stillwater, MN
mkIIIman089 said:
:umno:
mvpmotorsports.com
suprasport
I've got them on the shelf right now.
Jack
SupraSport
boost fiend
852
Rockford, Il
get the apexi from suprasport. 15 hp increase(advertised), no oil, best filtering. plus you get to hear the turbo a lil better if you listen hard enough.:evil2:
i have one and it rocks!!!!well worth the money!!!!!!
a k-n is just gonna destroy your afm. $400 is not cheap for a new afm.
just my .02 take it how it is.
92turbo4life
1,289
wherever
hmmm ao ia it worth it and im still new at learning... im still reading the maft pro shit.. what is the afm and how will it fuck up and why etc... thanks.
i feel like a newb but my info is all here just not some of the shit. i know alot but i still kinda learning some of it
