why would this block crack?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Superjustin13: It's not up to me, but I for one, do appreciate your help.
For the record, I am not saying your theory on over heating is wrong. It is totally possible imo. ;)
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
vote dat shit.
superjustin13
FTW
jk Thats what im here for. i also help alot of people on aim.
But yea....
Now you have 3 reasons why it might of cracked
My 2.
and Joels the coolant froze.
he stabbed me in the back with my own reply to other thread.
bravo man.
bravo.
:cry:
8,897
Rapid temperature change can cause a crack.
Since it is right on the bolt hole, that is probably the problem. And since he said he put a breaker bar on it, then that is even more likely.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Could a frost crack let coolant into the head bolt threads through the crack, then rust up and cause the same problem breaking the bolts loose? Just a thought.. :)
8,897
There doesn't appear to be rust or tearing in the hole. Maybe the shock load of it breaking free, and the metal in poor condition.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I agree. It does look like a fresh crack Nick.
LOL Justin, No arguements here..
Tig: What did the threads on that bolt look like if you remember?
Allan_MA70
1,055
Melbourne, Australia
Superjustin13 said:
Arguement is over
The Supermod Superjustin13 has Spoken.
I am Always right.
Xoxoxo
ummm dude dont get your hopes up for mod duty i think you will find most are >1000 posts and your constant beging is sad and im not even the one your asking! :boobies:
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
Dont be hating, im right 90% of the time. So dont hate the player hate the game
Turd Burgeler
. lol i hate how mods can edit posts.
Dont edit this one.
LOL im being sarcastic about being a mod
So remove the tampon
and this wasnt at ALL directed to you
edit: notice how i say JK after it all. so honestly im kinda getting Adjitated *SP*! (and I wear pink plastic underwear)
tig321
151
Edmonton/Victoria
The threads on the bolt were fine. That bolt was not as tight as the rest but was still tight. I remember that bolt because it was the only one that came out wet with coolant. (I was worried about a blown hg)
I went and looked at all the head bolts and they all look fine.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Superjustin13 said:
Imo. there could be 2 things caused.
1. The block heating up, (overheating) and the block Disipating the heat to Fast.. Looks like a crack due to heating to me
2. There was Shit in the hole when he tightened down the headbolt which caused it to crack
hottscennessey said:
looks to me like a headgasket repair.. possibly torqued way too tight with crud in the threads, and then overheated.
Yep - that's what it looks like to me. This is why you want to chase your head bolt holes before you install that shiney new ARP hardware ;)
tig321
151
Edmonton/Victoria
On the week end I pulled the engine apart and found a few strange things.
I found red rtv sealant on the front ngk crankshaft seal and oil pump shaft seal (koyo is stock I believe). Also on the spark plug cover (the threads of the thing with the large 14mm allen heads) and the rear coolant hoses. I can't see a professional mech. doing these things. I'm geussing an amateure hg replacement that was way over torqued, and possibly the other contributing factors mentioned. heat or something in the threads.
And to show Joel W's theory is possible here is a pic from the local machine shop. Its was a blown 454 inboard boat motor that had water in it over winter.
(we have mild winters where I live only got about -2)
