Joel W. said:I would have to guess that the coolant in the block froze solid and cracked the block at some point.
I have not seen that before..
amd_hcds said:Well I saw such case on a 2jz-ge on a chaser there was a coolant leak and it leaked all the coolant and the temp was full and the engine grow red and the owner was a woman she pooped the hood and saw the engine turning red so she "solved the problem by thrwoing water on the engine itself as to "cool" it and everything in the engine was messed up..was gonna rebuild that engine but the block was cracked just like yours is and kinda more but yeah..heh
hottscennessey said:looks to me like a headgasket repair.. possibly torqued way too tight with crud in the threads, and then overheated.
tig321 said:I'm not sure but would the head not be very warped if the engine was so over heated? I checked it and it seems straight around.004in. I have a head from another engine that I know was overheated and it's bent about 020in accross its length.
I did a quick google search and found that the inland basin areas in Japan commonly see temps of -30C(-22F) the coldest ever recorded is -42C.
Superjustin13 There are many people without a perfect coolant mix
especially when the coolant system (ie. overflow) is not working properly, since most people top the rad with water.
Thanks for your opinions. I gotto go look at some engines now.
Joel W. said:That is a good clue, yes and it supports my theory,
