Too bad that Audi has not decided to bring the excellent turbo diesels they sell in Europe here to the States. (They have V8 and V10 twin turbo versions that have excellent tourqe and drive quite nice.)
The V10 did come over for a brief time in the Toureg, but nobody here bought them, and they stopped building them for this market. (Great news is a few hundred are here, and the used prices should be falling soon, so it will be time to pickup a Diesel Toureg for my Wife one of these days... LOL and convert it to run on used fry oil... LOL )
The FSI direct injection on the R8's was totally reliable, and as they proved, kicked ass in racing. (They pretty much won everything they entered.)
For a turbo engine, this is totally the way to go. You can compress the living daylight out of the intake charge because it's only air. There is no fuel added untill the computer decides to add it. (Just like a diesel.) Think about this for a second too. On a normal fuel injected setup, some of the displacement is used up by fuel... So by removing the fuel, you instantly take the same "size" motor and make it slightly more powerful just from that fact that there are more air molecules in the chamber taking up space where fuel would normally be. Compress this, and it get's even more interesting. Put in your 500f temp air at 40psi... The engine does not care. There is no fuel to burn yet. Then right as the piston get's to the right point in the process, the fuel is introduced and the spark is right after it. (Of course, at this high of a charge temp, the spark is really not needed... The fuel lights off just from the heated air alone, and you keep adding fuel as the mixture burns... and the piston is forced down as the burning fuel and air expand... No detonation, no chance for pre-ignition and the pressures you could work with are way over what we have come to expect from gas turbo charged engines.)
Also as noted, under light load conditions, you can run very lean, and since your adding the fuel right at the point where the plug is located, the local "rich" spot there allows the lean mix to light off, and you have good lean burn with very little left over hydrocarbons. (Good for even the crazy state of CA.)
What Audi needs to do is sell me a twin turbo V10 FSI engine that runs 25:1 at cruise, and under boost makes a nice 800 AWHP
Mmmmm. 30+mpg fuel economy, and in a car that will haul the family around in comfort, and still put down a nice 12 sec. quarter mile or better.
