Why is my coolant brown/black?
Justin
Speakers?
Spokane, Wa
Fresh engine, 2200 miles on it... pulled my radiator out to pull out the AC condensor... drained the coolant and this is the gross shit that came out...... what's goin on?
dbsupra90
toonar
indiucky
MDCmotorsports said:
Rust or exhaust....
yep. also ive noticed redline water wetter will make the coolant a funky color.
id give the coolant system a good flush then refill. also may want to scrub up the overflow bottle. they often get a layer of grunge on the inside over the years.
Bishop92t
773
USA
www.ma70.com
Fresh engines can make some funky liquids. In between the new gaskets and assembly lube it's quite a mess. Flush the system if the gunk returns then start looking for a problem.
chriso
Supranian
Bay Area, CA
Yup and the leftover rust in the block that you couldn't get out.
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
just flush your cooling system ;) Mine had same color after last rebuild, so i've drained it, cleaned with special liquid cleaner and now I have nice, red coolant ;)
