Fresh engine, 2200 miles on it... pulled my radiator out to pull out the AC condensor... drained the coolant and this is the gross shit that came out...... what's goin on?
MDCmotorsports said:Rust or exhaust....
Yup and the leftover rust in the block that you couldn't get out.Bishop92t said:Fresh engines can make some funky liquids. In between the new gaskets and assembly lube it's quite a mess. Flush the system if the gunk returns then start looking for a problem.
