why do people hate eagle rods
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i bean looking around and alot of people don't like them why is that
reson being i can get a set for fairly cheep
i herd about the stock arp bolts are junk thear w3as a thread on sf about them
cause i wana get rid of my stock race preped rods
suprarich
Guest
Nov 9, 2005
2,187
ohio
Old wives tales. The arp rod bolts in all modern Eagle rods are 3/8 bolts. Much stronger than the stock replacement arp's for stock rods, and loads stronger than the stock toyota bolts.
AJ'S 88NA
2,419
Florida
I guess they have different rods. I have eagles and they are a "H" beam type with ARP studs. They came with my stroker kit and they are SB Chevy's, don't know if that makes a difference. I couldn't say you can get the stock size in the "H" beams. They looked pretty stout to me, and they are lighter than the stock ones.
fstlane88
Single time!!
South FL
FWIW, I helped work on a 542 BBC that had a Eagle rotating assembly, and J&E pistons. On motor it made 1000hp, and had a Fulton dual stage nitrous kit on top of that, so in all the motor was making around 1600hp. Where I'm going with this...every time the motor came back to us, it had melted a piston, so that's is what we'd replace, still to this day, to my knowledge the bottom end on it is still intact. I guess I could add in, if it makes a difference in anyones opinion, that this was an 1/8th mile car, a 5.20 1/8th mile car.
Personally I wouldn't ever hesitate to run any of their stuff.
cuel
1,536
Baytown, Texas
How odd... I have a set of stock rods out, and was talking to a friend about polishing and balancing. He commented on how similar they are in dimensions to SBC rods, and thought maybe I could interchange them if I could find the right ones. Seems stock(Toyota) are pretty close to 6", just have to see if the ends are the same, or maybe get SBC pistons that fit in the 7m... Still have some research to do.
AJ'S 88NA
2,419
Florida
Not sure if the length is the same. another thing to consider is the dia of the journal, wrist pin.
the reason eagle rods are looked down on is because they're not as good as many of the others on the market...
I wouldn't hesitate to use them myself, but it's come down from the MKIV crowd and saying they they're weak and they fail at the bolts...
Doward
4,245
Alachua, FL
:rofl: No offense, but I haven't met many MKIV owners that I would trust to work on my '88 Accord, much less trust them with internal engine work ;)
TurboWarrior
Canada
soooo true they usually have the money to pay someone else.
shaeff
Kurt is FTMFW x2!!!!
11
Around
i think it was chris bell (flubyux2?) on SF and here that made an informative post about them. if i recall correctly, he said that they have to be shotpeened before use, and after that, they're plenty strong.
i'm just puking this out from memory, so please don't quote me on it, but i'm almost certain that's what i read.
Doward
4,245
Alachua, FL
Eagles are shotpeened from the box.
As for Eagle's quality, the strength has never been in question for me - only the tolerances of machining.
