Hi,
I change the CT26 for a T4, but I can't boost more than 9.5psi. :aigo:
I have a Digital boost controller Boost controller (AEM True boost controller) and I setup to 18psi but with out luck :cry:
Turbo Parts install it:
Wastegate:
50mm Valve
Die Cast Body, Billet Steel Valve, High Temp Silicone Diaphram
Capable of supporting up to 1000hp, 10.15 Psi Spring
In the top, don't have any bolt! is normal???????
TOYOTA 7MGTE STAINLESS " 321 " TURBO MANIFOLD
Presition Turbo T4, Hot side .68 A/R, Cool side .70 A/R
What do you suggest, I don't found any air leak, WHAT CAN I DO?:cry:
Wastegate:
50mm Valve
