Why BOV WHY!!!!
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
hvyman;1554743 said:
What turbo are you running?
Loosen it as much as possible. Just make sure no air comes at idle and it doesnt open before full boost.
IM running a Stock ct-26 Turbo but i have it at 13lb of boost ...im going to send my spare turbo to Driftmotion for rebuild i want the 54 trim sincei heard it spools faster then a 57 trim but thats another Subject lol...BAck to the subject u said i should loosen it as much as possible without any air slipping thru at ilde or boost .... i just revv it at idle and look at the BOV right?
Hold your hand feel for air with the hood open. Not much you can do but listen when driving.
I have a type s and its loosened all the way with a 57 trim.
P.s. 57 trims spool quick.
noel
Uchiha Member
May 5, 2008
512
Type S wat?? ill try that 2morrow.. but wouldnt the BOV leak under boost if so i can test that with a Boost leak test right>? wat trim is stock Ct26?
P.s Quicker then a 54 trim>?
