why bother going bigger than 264's?
suprarich
Guest
Nov 9, 2005
2,187
ohio
IJ. said:
Rich: LOL :)
The Cams Gary runs in his 7M rail are sort of square with rounded corners I'm not sure on the specs but they'd be some of the biggest in a 7M I know of!
I have a print out of his cams tag. Very interesting grind and a stagered set to boot. Dr/paitent relations will not let me reveal his cam profile however.
Sawbladz - There are many more numbers to look at than just the few you mention, but like it was already said, it is enough to compare cams. One set of cams can act like several sets by how you time them also.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
ok, i think i get where you people are coming from. the way i thought of it, was the increases would be proportional.
a "272" would make a larger % increase over a "264" on any given setup.
but it sounds like you guys are saying a "272" will make marginal gains on a motor with a setup for under 600hp but would start to make more discernable gains on a setup for 600-900hp range? in that case, would the "280"s be out of the question for a 7M with a ported top end, 4 liter surge tank manifold and a 76mm running at 36psi?
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Assuming a beefed up and lightened valvetrain to be able to make use of the extra RPM you'd want to spin, no, they wouldnt be out of the question....
some specs on my cams just for shits....
288 duration @ 0
264 duration @1.25mm (.049")
12.5mm lift
also have intake/exhaust opening/closings too if anyone was real curious....
suprarich
Guest
Nov 9, 2005
2,187
ohio
You still need to stop refering to cams as 272, 264, blah blah. That is not how you measure the relative size of a cam. I have cams that are 272 duration but only 7.7mm of lift. Basically a slight upgrade from stock. then I have 11mm lift 272 cams that you would find in a 1000 hp motor. Do you guys see that these "advertised" durations are worthless jargon?
The question you asked about the 280 cams for your built 7m means nothing because just saying "280" means nothing.
Vas: 288 advertised would be around the 230 @ 50 and 11mm lift makes them a fairly hot cam for a Turbo motor but I guess GrpA didn't care much about Idle or drivability down low ;)
vas85
SupraNut
Sep 29, 2006
391
Sydney, AU
IJ.: Yeah, excellent info from this thread aswell about cam lift, as I wasn't aware of those aspects, all I knew was bigger cams = less driveability. I agree GrpA didn't care about idle / drivability, although can't idle be adjusted to be little higher 900rpm? 1000rpm? then it would make it more driveable...?? just a query, or does it not work that way with cams?
Vas: Yep most cammed motors have a higher than stock idle (some just plain won't run slow no matter what you do)
Tune and accessories make a big difference my old Wolf wouldn't idle much under 1000 rpm without sounding like a top fuel motor but the MoTeC is happy at 700. (Trigger system change is the difference between the 2)
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
rich, i dont think you understand what you are asking me to do...
you want me to stop referring to various sized cams by any semblance of a name. perhaps you have a better way to differentiate between several cams? i mean, its not like I made up the names for these cams. HKS did.
and yes, i know you can have 2 completely different cam profiles and still call them both by the same name due to the seat to seat duration.
seat to seat of 272 doesnt mean shit, i know this... stop telling me this. i knew it 9 years ago. im not calling these cams by the names given to them by the retailers because i dont know any better, its because everyone ELSE is already familiar with the perceived stature of these cams amongst the tuning process.
the valve events are whats important. i had cam cards for a car that made 680rwhp at half throttle... a guy named atomic fabio, maybe you heard of him? i wish i still had those cards. the duration at 0.050" and the lift was pretty crazy. the actual duration was very very close to the advertised duration yeilding a really aggressive ramp profile, which is what id like to see in a custom cam... assuming the cams can be dynoed to help me decide what valve springs have to be run with those cam profiles to avoid float or bouncing on the seat because of the ramps.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Sorry buddy.. I am not trying to offend you. I know you know the difference between advertized duration and duration at .050
This is not what I was trying to say. It is lots of peoples fault on here that everyone seams to relate the size or power potential of a cam directly to its duration. This is the only web site i know that says duration in relation to a cam first. It is lift anywhere else that is aways mentioned first.
Since hks only has a few cam grinds, it is ok to say hks 264, hks 272, because everyone knows which cam its. But when people who don't know, start saying only 272 or 264 as a cam size, regardless of any manufacturer, then I feel like I have to pull my hair out. The reason, as you know, is that there is more to a cam than its duration. And to simply say that 272's are bigger and more powerful than 264's is wrong. Then every person who does not know, simply thinks this is the right way to measure a cam, then they run out and start buying the wrong cam for their set up.
People who know about cams have a duty to set this straight. Instead of asking " Do 272 cams make more power than 264 cams" We need to really ask" Do BC cams .324 lift 264 duration cams make more power than BC cams .353 lift 272 duration cams.
It is like saying are "265 tires better than 255 tires"? We don't know, Who made the tire, what is the rims size, what is the tread compound...
Gets worst when you ask about cams for a motor that 10 different manufacturers make a cam for.
Cams are referanced in terms of who made the cam first, lift second, duration third, duration at .050 fourth.
Leave out any of these four when speaking of cams in a compairitive way and the comparison means nothing. There are at least 10 more numbers to worry about when you really get into it. But to reference two cams, the 4 items above are enough.
p5150
ASE and FAA A&P Certified
Central Idaho
For anybody that wants to know, the regrinds I have for my 2jzge-> T are a 260 duration at Zero. 220 @.050" with a .355" lift (about 9mm of lift)
This is the best you can get out of a regrind without cutting down the base circle too much.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I wish the 7m had that big of a base circle to cut a cam that large. Good Grind you have for a re-grind. Most advertized 264-272 duration reginds may only see a 213 to 218 at .050
Is your regind specs for valve lift or cam lift. Would be really nice if they are valve lift.
p5150
Central Idaho
Well the card has a .355 listed for both "valve lift" and "camlift" with a .010 int and .012 exh lash clearance. So at worst it is a .345.
I dont know if they included the lash or not on the measurement
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
fair enough, i gotcha. its no problem.
was mainly speaking in regards to the same retailers version of small medium and large. say, why would someone want an HKS 272 on a car that is under 600rwhp capable when an hks 264 would be a win-win situation.
i can see your frustration when talking about a BC 264 and comparing it to an HKS 272 or whatever. because the BC may have higher lift w/ less usable duration, it could make more power under the curve than the HKS 272. Or a Toda cam of the same nomenclature could make more power under the curve for more RPM than an equivalently named came from another guy.
suprarich
Guest
Nov 9, 2005
2,187
ohio
That is it in a nut shell.. Most guys just spit out advertized duration having no idea that from one cam to another and from one manufacturer to another is two totally different cams.
