Edit: i should have said "bigger than 264's"...
i mean... whats the point?
according to HKS' dyno graphs of their own cams, i dont see much of an appreciable difference between going bigger than 264's. this is all in reference to the 2J, but the 7M is still a 24v, 3.0liter setup. the bore/stroke and rod ratio isnt that relavant of a difference between the two. the only main difference would be the VE of the two. however a stock 7M and a stock 2J (gte) differs only by about 25cfm at the highest flow rating... so whatever the 2jzgte does, the 7m is only a step behind and with a power band shortened by ~1000rpm (stock for stock).
so, that said... the 256's made an improvment, and then the 264's expounded on this improvment. however, the 272's lost low end and didnt yeild an improvment on the top end...
im only worried about TQ since thats a directly correlation to the VE curve of the motors themselves... but check it out:
alot of you are going to cite variables in valve size, intake manifolds, compression ratio, exhaust manifold, turbo size, boost level, fuel type, conditions or anything else... im not focusing on that. im simply talking about how a motor will react to the "benchmark" for aftermarket cams with all other aspects being equal.
