Why are my Manifold Air Temps OUT OF THIS WORLD!?
sk6471
Quietly Lurking
May 28, 2005
91
Texas
Just think, your IAT sensor isn't even measuring the temperature increase from running the intake over the top of the turbo yet. I'd be interested to see how hot it is at the throttle.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
nosechunks;1428288 said:
As I said, compression causes temprature rise, at 14.7psi the temperature would effectively double from compression alone. Add in the ineffeciencies of the turbo and intercooler result in that. Imsure the air your turbo is compressing isn't the same as outside temperature because I'll bet your intake is under the hood near the hot manifold and everything else. That just adds to it.
Yeah, I agree and see what you're saying. What's really throwing me for a loop is looking at other logs and only seeing a fraction of the temp increase that I'm seeing.
It'll be hotter. Instead of roasting a chicken, I'd be able to roast a cow!
IJ.;1428342 said:
30c/86f cold>74c/165f hot before the ramp
Thanks IJ. That actually helps because that similar to what I'm seeing.
Anytime you compress AIR it get's hot CK, that's the IC's only job and depending on how big/efficient it is will determine what you see at it's outlet.
This is why I often mention how good a W2A is in a daily driver that see's stop start boost, they just stomp all over an A2A being an active system and not relying on the car going forward to cool.
A2A's just heat soak their brains out in traffic then your Temp compensations kick in and effect the tune and the car's behaviour, early on I found AIT sensor placement important, I had mine in the manifold where at idle it would get minimal airflow and heatsoak badly.
I now run both sensors in the pipes outside the bay on either side of the IC then write my compensations based on their output.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Yup, had the same problems here, when I had the sensor mounted just before the throttle plate, on top of the engine.
The problem with heat soak like this is that it calculates the air going in using a temperature that's too hot... and this leads to more air in the engine than your computer thinks there is, or a lean condition.
I'd rather have a setup that, when it malfunctions, measures too much air, and therefore makes for an overly rich situation.
CajunKenny
Nov 15, 2007
3,255
Washington
So then is the common thinking that I do have a problem? Or is it just one of those issues that isn't necessarily a problem; but, could be improved upon?
I understand what grim is saying about heatsoak causing a lean condition. This is obviously something to avoid. That is why I mounted my AIT where it is.
There is another location that I might be able to utilize. It would be just under the headlight which isn't far from it's current location; but, would be completely out of the engine bay.
Here's another approach that comes to mind. I'm going to use water/meth here in the near future. I had planned on having it start injecting at ~15 psi on up. Would that negate the need for relocating the sensor and/or converting to a W2A setup?
Would a W2A setup be compatible with Water/Meth?
Sorry for all the questions... :)
grimreaper
2,180
Dallas
You could stick the sensor right behind the air filter. Runs a bit richer (well, before tuning) but creates the safety net grimjack speaks off.
try putting the stocker (IC) back on and see if you get a better drop in temps through the IC. Other wise you might try re mounting the AIT sensor under the headlight right after the IC outlet.
id consider the stock IC to test it, maybe the replica's really dont cut it?
CajunKenny
Nov 15, 2007
3,255
Washington
Could be.
I suppose I could just install the SP61 and see what happens.
What are you seeing for a temp increase?
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
To be honest, I don't think I'd worry about it. Your temps are still very reasonable. I run a very similar setup on my car - temp sensor in the same place, air filter in the same place.
If I were going to change anything, it would be to build a box around the air filter, so it has to suck in cold air from the headlight area instead of hot air from the engine bay. Actually, I'm working on getting that very thing... :)
quark
27
Denmark
My Carlos Sainz with WTA intercooler drop in temperature when acc. Maybe WTA is the way to go, it got 10 degress colder. (pump always on, so that not it ;-) )
SacoMan
56
Spain
www.supraclub.es
Wonder how many here know you are refering to a Celica 2.0 Turbo 4wd :)
quark
27
Denmark
Look at these
Original CS WTA cooler. Super t70 turbo, MS2 extra EMS.
1 bar pressure at these ones. Red line is MAT, Purble rpm
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Fwiw I had my car out today roughly ~50f ambient. IAT in inlet to turbo and was seeing 90f temps while driving. No temp sensor after IC so who knows but that's intake underhood temps.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I'm in agreement with the others here that you're worrying more about this than necessary. The location of your IAT is the same as most of us run without problems. I also agree you need to get the air filter out of the engine bay or box it.
If you do want to move the sensor out of the bay altogether you can adjust for it with the temp correction table in the Pro. I do not recommend placing it before the IC or turbo though.
