Who knows this?
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
I think I've read numerous times that if you can unplug your AFM (with the car running) and if it doesnt affect idle, then the AFM is bad. You really shouldnt have to since the above is happening, but you could just test your AFM to be sure. I'm having this same problem warm engine = bad idle and i've narrowed it down to either a bad ecu temp sensor or TPS. If Maybe check TPS next
pingerpar
Wanting another supra
Aug 14, 2006
34
St Charles
figured it out, tps was bad, switched it with another, car runs good now haha tahnks for the help guys, the code 51 didnt show up when i checked codes when the car was off and then i checked it with the car running and it showed up, so i swapped it and now its fine .....hopefully
