bigaaron said:
I think you are spreading some misinformation on this for sure.
The hydro fan is variable speed, it even has it's own ecu. It can be on high while you are sitting at idle, or it can be on low while you at high rpm. The hydrofan on high pulls more air then any electric fan you can buy. The hydrofan has all the benefits of a mechanical fan and an electric fan.
There is no stock temp switch on a Supra that is suitable to switch electric fans. You want to get an aftermarket 180 deg switch placed in the radiator.
Yes, you're right about the hydro fan having regulated speed, but it doesn't move as much air when your engine is idling as two e-fans, the oil pressure is simply too low to generate enough power to spin the hydro fan fast.
No one over here is running the hydro fan, we all ditch it because e-fans simply flow much more air. When mine switch on, I can feel the hot air blowing under the car, throwing up quite some dust. The hydro fan does not do that.
And the stock thermo-switch IS suitable to switch the e-fans, I've been running mine for over 5 years without ever missing a beat and my temp gauge is allways rock solid in the middle, never goes up or down.
The relay, wiring and thermo-switch is reliable; it has been engineered to last.
