Who are the 1J experts here?
rakkasan
Currahee!!
Fort Campbell, KY
I've read the faqs, but pass along some of the things you wish you would have done during your swap but you didn't know to do. New front & rear main seals, hoses, etc are a given, but is there anything else that you wished you would have done?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
If you are keeping A/C, make sure the compressor is in working condition and not seized.Aslo change the AC compressor's top plate as well so that the 7m acpipes will fit.
These are little things, but snnoying to get to after engine is in.
Also, put on the 3inch y-pipe and downpipe while the engine is out of the car.It is a pain inthe ass to exchange those after engine is installed.
Plug in the boost controller hoses to the waste gate of the rear turbos as well, since it is hard to reach when the car is in the engine.
Clean the engine before putting it in...
rakkasan
Currahee!!
Fort Campbell, KY
I'm going single right off the bat. Paint the block, polish the aluminum, ect....
Thanks for the info!
OneJoeZee
Retired Post Whore
aboard the Argama
on my second engine i ordered a gasket kit and just replaced all the important things. I don't expect anything to fail on this engine anytime soon except maybe the turbos...
rakkasan
Currahee!!
Fort Campbell, KY
What did you pay for it & where did you buy from?
rakkasan
Currahee!!
Fort Campbell, KY
Also, what's the deal with GEMU & Emanage Blue? I'm guessing that GEMU can't be made to work (or all of the options at least), that's fine, so is Blue the way to go? Also, can blue control the injectors & timing?
OneJoeZee
Retired Post Whore
aboard the Argama
well actually let me step back. i think it was 138 + ship. but that was like about 10 bucks or less or something so its still cheap... considering you get the full gasket kit.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Depending on how many miles are on the engine, it may be a good idea to change the timing belt and serpentine belt before you stick it in. They're a little bit easier to get to with the engine out, and if you're going to be changing stuff anyways, might as well do it.
And, if you're keeping the stock turbos, I would suggest redoing the vacuum lines to accept a boost controller now, as the lines on the rear turbo are next to impossible to change with the engine in the car.
Hydrofan is great because it can flow an insane amount of air to keep your engine (and engine compartment) cooler.
rakkasan
Currahee!!
Fort Campbell, KY
I know that GEMU has it's problems, but how about Emanage Blue? Isn't BIC running it? I'd love to have timing & injector control, so any info would be great.....
I
itr206
Guest
GEMU sucks donkey clit.
I had it and it blows. HamsMKIII blew his motor on it.
I now went to the EMB because It sproven to work.
