OK my supra got some quality time today. I thaught i had a BHG and i knew i had a wiring problem. I thaught it was a horrible wiring probelem but just a loose wire to my CPS that finally killed over..easy fix. But the problem i am concerned about is it is pouring white smoke. I thaught it was under acceleration well at least it was yesterday. I ran a compression test on it today and all the cylinders were above 135. Today it seemed like it was when i let off the throttle...Iv heard synthetic burns white i run mobile 1 full synth.Could that be a possiblity? i also have just a downpipe on there right now the second cat cut off...I had the valve cover gasket leaking alil while back so i replaced it i thaught it was oil dripping on the downpipe that was burning off but i thaught it should have burned off by now? maybe? Could it be a cracked head still maybe? Valve seals? by some wierd chance fuel? anyways hoping for a good suggestion to try out thanks guys
