foreverpsycotic;1486806 said:SEARCH. Jesus Christ.
tissimo;1487001 said:If you're going to buy a denso new, skip it and just buy a bosch 044.
suprahero;1486853 said:Mike, I'm not sure he's going to find the answer to this question through God.
He may want to look at the technical section of Supramania though..........:biglaugh:
GrimJack;1486857 said:BAD foreverpsycotic. No biscuit.
Do *NOT* pull the search card unless you are willing to teach how to use it, dammit. That means explaining why it would help AND posting pre-tested search terms that find relevant information.
I've said this many times already. Simply telling people to search is a fast route to destroying the forum. Cut it out.
IJ.;1486882 said:JC prefers the Mk4 Denso if he's running less than 20psi boost
Flateric;1487055 said:I upgraded my MKIII intank denso to a MKIV intank denso because I do not like the sounds of the fuelpump whinning away.
I suppliment the intank with a inline walbro that enables as needed determined by boost. Controlled by the ECU.
But the intank denso will run and sound exactly like your old stock pump. Which was the big selling point on it for me anyways.
