which cams
slowpra na-t
Permanently Banned
Oct 16, 2008
132
murrieta ca
which cams do you think would work better i am running 15psi, have upgraded fuel system, intake, exhaust, ect.... ok so i have two sets of cams one set is by ruben racing, and the other is by crower... the ruben cams are intake and exhaust 330 lift with 203 duration...... i've had them for a while never used them.... the crower cams are intake and exhaust 320 lift with 221duration.... does any one know which is better for a turbo 7m lift or duration???? please help!!!(i really dont want to put one set in, test it, then test the other set...way to much work!)
92nsx
2,957
Clearwater, MN
way to much work, what are you talking about. A cam swap takes less then a hour from start to finish. Call a dyno shop and ask them what they would charge you so you can test the two cams, with you doing the labor on the cam swap and timing them in. This is the best way to see what cams are the best.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Dyno time is expensive! Why would he want to pay that kind of money to work on his own car?
suprarich
Guest
Nov 9, 2005
2,187
ohio
The ruben cams, are the specs at .050 lift? What turbo are you running? Because just saying 15 psi does not really mean much. Where in the power band do you want the power to be? Both cams would be best for a certain application, but what results are you looking for? Street driving with good mid range, or racing top end power?
slowpra na-t
Permanently Banned
Oct 16, 2008
132
murrieta ca
no 330 lift is not at .050.. i was told they were stage 1 cams. i am running the stock ct-26 turbo. my power band right now is from 3000rpm to 5500rpm, i would like it to be around 2500rpm to 5000rpm... i want street driving with some good mid range.:1zhelp:
cruisnhard
SM Member
Sep 27, 2007
236
Waupun, Wisconsin
I agree with suprarich. You have to determine where you want ur power first, then u can better decide which cams to use. Then sell the other ones for dyno time money!
92nsx
2,957
Clearwater, MN
Not that expensive, around here dyno time is 80-100 bucks a hour. So for less them 200 you can have PROVEN #'s that show what set of cams are better.
How to do it, LOL> Enter dyno with one of the sets of cams already one the car. Take a pull, and get the #'s. Then swap cams on dyno, (less then a hour if you know what you are doing;)) take another pull, compair #'s then just stay with the best set of cams. If it was the first cams then swap them back in once you get home.
The key thing is now you have proven witch ones are better, not just guessing.
Tun_x
Built to do the NASTY!!
Utah
Here is what I did ... I took my cylinder head flow tested at several different lifts found out
where my # were and ordered a camshaft accordingly .... this is the short version of the story..
I don't like guess work
Jason
suprarich
Guest
Nov 9, 2005
2,187
ohio
You would want a shorter lift longer duration cam for a low end power band. I still do not know the full specs on your Ruben cams. The only true measure of a cam is at .050 lift. Advertised specs are not 100% worthless but close. If you cannot find the specs for the cams, your only recourse is to do the dyno tune thing with both sets to find which makes the best power in the range you are looking for.
