um, all over the place. this thread is for a 7.25in clutch. tilton, quartermaster, sonic and tons of others make the twin and tripple 7.25in clutches. iirc with the r154 you cant use a tripple. too thick. im using a t56 so hopefully i got enough room for the internal slave cylinder. the flywheel im guessin will be $300-400 by itself, then whatever it costs for the slave cylinder. they make them dif depths and diameters so ill have to wait for the flywheel before i can measure to see what i would need.
check this site out.
http://www.bsrproducts.com/index.php?cPath=10&sort=3a&page=5
btw, tilton used to make the flywheel needed for the 7.25in clutch out of aluminum. called them, they said titan buys every supra flywheel they make, called titan and the 7m flywheel is discontinued, they wont reproduce uness they can get 10 irders. if i thought 10 people would buy one id tell them to do a group buy, but since i highly doubt 10 people would seriously pony up the cash, im getting a 1 off from quatermaster made of steel(my preference, dont want the whole setup too light)
also, i ot my tripple used on ebay for like $130, i plan to buy new discs. its $170 for the 3 pack of organic discs i want to use. since i have a t56 its an off the shelf part. so $300 + the flywheel and the internal slave setup. should total less then $1k
