lol $5, I will just open my tool box and grab the tap I have in there.gofastgeorge;1440112 said:That picture was of a strait thread fitting, not a pipe thread fitting.
BSP, and NPT are almost identical except.........
Actual thrad profile differs slightly, and thread diameter on the NPT is just a little larger than BSP.
Easy fix........
Run a NPT tap into the BSP port just a few turns, and it will now be a NPT port.
I too have used NPT directly into a BSP port, and got away with it.
The fitting ussually will not thread in as far, and you end up with few threads holding it.
But for $5, you can pick up an NPT tap, and all will be good.
Since they are tapered threads, you don't want to run it all the way in,
but just until it starts cutting, and a turn after that, then re-try the NPT fitting.
If not deep enough yet, do it again.
If you goo too deep, you may end up with an oversize hole, and then your screwed.
So just do a little at a time.
4U2QUIK;1440108 said:you can just re-thread the british straight pipe thread with a same sized npt tap. I do this all the time. Works great 90% of the time. the other 10% is when the bspt was drilled the wrong size to begin with.
the npt and the bspt's are the samme thread, just one is tapered so it seals up.
4U2QUIK;1440348 said:BTW I'm an inspector at a very high end machine shop.
and I have over 12 years machining and programming experience.
gofastgeorge;1440353 said:But that doesn't matter to a forum master..........
92nsx;1440270 said:The order has been placed for the CORRECT fitting along with a few extras
90T04;1440395 said:I thought it had to be something other than steel?
IJ.;1440372 said:My "take" on the issue...
In the past I've retapped an 1/8 BSPT to 1/8 NPT, is this the best way to do it? NO but if done carefully it works fine.
I also worked in industry with hydraulics/pneumatics and as long as you don't cut the new thread past about 50% of the NPT Tap depth it will work fine with a little thread sealer of your choice.
Go past 50% and you end up with a "Dick In a GumBoot fit" that will NEVER seal.
